Guest diggy Posted August 22, 2011 Share Posted August 22, 2011 well where should i start at first i thought the fuel pump had gone so did that and that was not the problem so checked the fuel pump relay and all the fuses and yet again that's not the problem so now been informed ( by a mate who has had the same problem) that it could well be the immobilser not going off. I have a toad alarm and immobilser on that cuts the fuel pump and ignition so i was wondering could i simply have the old one removed and a new one fitted as that would be as cheap to do as getting it fixed! anyone got any suggestions on the matter would be helpful Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 22, 2011 Share Posted August 22, 2011 That probably wont solve the problem. If you have an imobiliser that cuts power the pump they will have cut the supply or relay cable and then either inserted a remote relay or depending on model and intergrale one inside the alarm. You need to identify where this is on the car as you need to bridge the gap or insert the new alarm to this point. If you can't find it you will need to route new cables. Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted August 22, 2011 Share Posted August 22, 2011 bugger! that sounds alot of hassle will scrap the bloody thing and get a new one me thinks lol Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted August 22, 2011 Share Posted August 22, 2011 my toad live feed was just under steering wheel cowl by muti plug.... look on internet for wiring.... most stick the black box up behind glovebox and trace the wire hope you dont scrap your cabbie Diggy Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted August 22, 2011 Share Posted August 22, 2011 not scrap the thing as i have grown very attached to big red but must admit the car does my head in sometimes lol Quote Link to comment Share on other sites More sharing options...
