Fuel Pump Issue
Guest Benji78
Guest Benji78
Hi All,
I've got a 92 1.8 cabby,
Should the Fuel pump keep running once the engine has fired??
Only my one seems to run all the time have fiddled about with what looks to be a kill switch drivers side footwell as every now & then the pump doesnt run unless i tap the switch a few times,
Any Ideas??
Thanks
Ben
pic is tiny, but looks like a fuel safty cut off to me, altho im not hot on mk5s, if it is there on the late efi mk4 modles, and you can cut it out and just join the two wires together. but dont take my word for it, hopefully someone witha mk5 can shed some light
Guest Benji78
Sorry for small pic!!
I think your right that its a safety switch,
Should the pump continually run??
Thanks for quick response
Guest Jack Tar
when you turn the ignition on you should hear the pump prime for about a second or so then you shouldnt really hear anything more from it.
The little box with a red button on it on the drivers side kick panel is the fuel cut off. whilst engine is running press the red button and hold it and the engine will cut out.
Where in hants are you? im just outside of pompey
