Oil Pressure On New Engine
MarineIguana
Right fired my new lump up and all runs sweet much better than the old one only problem is the oil pressure and its tappty :sad:
The oil pressure is showing @ 100psi at 1500rpm Which is way over what it should be :sad: but the tappets sound like they are running dry I know its not the cam or tappets as they are new so could the oil pump be knackered :sad:
