Guest diggy Posted April 19, 2011 Share Posted April 19, 2011 right to start with the washer bottle pump stopped working so checked the fuses they was fine so got a new pump still no joy so got a replacement wiper stalk inside the car and still no luck. so i am now baffled and was hoping for some advice as to what else to do! any thought's as to what's wrong would be helpful Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted April 19, 2011 Share Posted April 19, 2011 right to start with the washer bottle pump stopped working so checked the fuses they was fine so got a new pump still no joy so got a replacement wiper stalk inside the car and still no luck. so i am now baffled and was hoping for some advice as to what else to do! any thought's as to what's wrong would be helpful they aint many things it could be n you,ve pretty much covered everything.you could try connecting some spare wire to the washer pump n trying it on a 12v battery to see if the replacement bit is ok.check earths.double check fuses.test the stalk with a tester probe.other than that im out of ideas lol. Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted April 19, 2011 Share Posted April 19, 2011 they aint many things it could be n you,ve pretty much covered everything.you could try connecting some spare wire to the washer pump n trying it on a 12v battery to see if the replacement bit is ok.check earths.double check fuses.test the stalk with a tester probe.other than that im out of ideas lol. did the wire to the battery test on the old and new pump and both worked fine will check the earth wire and someone said it could be a relay but i not got a sodding clue which one lol Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted April 19, 2011 Share Posted April 19, 2011 The wiring for the pump goes behind the passenger side of the front bumper. It common for people to get this wire stuck between the bumper and the wing when refitting the bumper. Over time the movement will wear through the wiring stopping the pump working. Have come across this problem on every mk4 i've owned. Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted April 19, 2011 Share Posted April 19, 2011 will give it a shot may be that simple Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted April 19, 2011 Share Posted April 19, 2011 dont think there is a relay for the washer bottle? Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 21, 2011 Share Posted April 21, 2011 yeah as lee said, the wires for it can get trapped way too easily, happend to me and my mates mk3 tin top!! Quote Link to comment Share on other sites More sharing options...
