Guest dobs Posted April 15, 2011 Share Posted April 15, 2011 need some help is my engine completly knackered of do i have a problem with the breather system its a efi mk4 and im not sure if there is a common problem with the breathers or just my rings gone? any ideas please Quote Link to comment Share on other sites More sharing options...
welshlad Posted April 15, 2011 Share Posted April 15, 2011 all the ones ive ever had have been gunked up in the breather pipes so poss a common prob Quote Link to comment Share on other sites More sharing options...
Guest dobs Posted April 15, 2011 Share Posted April 15, 2011 all the pipes are clean but maybe thats not helping? Quote Link to comment Share on other sites More sharing options...
Guest avul Posted April 15, 2011 Share Posted April 15, 2011 hi dobs yes this is a comman prob, it could b the compression ring's worn that would over presurise the block or if as u say all the pipe's r clear? it could just b the engine is gunked up inside. u could put an engine flush thro which myt sort the prob, but b aware that this may make the prob worse as this can strip the the burnt on depossit's that may b protectin ur engine!! its a bit of a cat & mouse game on an old engine, it's leave it & live wiv it or flush it & c how it goes!!! other that that if u can afford it it's ave it out & replace or rebiuld, hope it's a small fix 4 ya tho, hope this is of help regards mark oh a bit of gd news i'v done plenty of engine flush's wiv no prob's Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted April 15, 2011 Share Posted April 15, 2011 What grade oil are you using? i remember using 5w30 in my old mfi, and airbox was swimming in oil, put 10w40 in, problem solved. how many miles it done? Quote Link to comment Share on other sites More sharing options...
Guest dobs Posted April 16, 2011 Share Posted April 16, 2011 the engine seams clean inside and has 89k on it its got 5w30 in it but think it did the same before think i will fit a recuclating catch thank or bailey breather as that will send it back to block just wondered if it was maybe a faulty std breather i have a 2lt black top that might find its way in there Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted April 16, 2011 Share Posted April 16, 2011 (edited) It is bad design and worn rings make it worse. A good idea is like you said is to fit a oil separator. S2 turbo item would be the best. Just need to make sure there is clearance on the intake. Never use 5w 30 in a CVH it is far to thin. Will do much more harm than good. I have found that Silkolene Pro R is the best in 10w 50. Its a high quality oil that doesn't vapourise as much as cheap oils. It will be thicker when the engine is up to temp. Your engine wont burn as much and the oil pressure will be increased to a better level. Edited April 16, 2011 by Lee81 Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted April 16, 2011 Share Posted April 16, 2011 silkolene oil is owned by fuchs,which is sort of a budget brand of oil, If you can, go for the castrol, it's about £25 for 4 litres, but you get what you pay for. Also, if your going to flush it, i would get some cheap tesco brand or something, run the engine until it's red hot, then change it straight away for quality oil and filter. Used an engine flush on an old fiesta before, it didn't like it. Quote Link to comment Share on other sites More sharing options...
