Problem Wih Mk6/7 Rear Led Light
Guest cybercypher
Guest cybercypher
hi all,
can someone point me in the right direction :punish:
i have just bought some rear led lights for my escort cab mk7
i have plugged them in and they are doing some wired stuff.
they dont seem to be working right it like there wired up wrong or something.
for example. you put the sidelights on and it only works on the drivers side so to eliminate them being daulty i plugged the passangers side one into the drivers side and the side light works :crazy: so i know they are not faulty.
i dont have a wiring diagram for the lights as it should be as simple as plug them into the exsisting loom.
has anyone else had this problem?? :crazy::crazy::crazy:
thanks
Edited by cybercypher
Guest tony.rose
Hi, don't know if this will help, but sounds like you need to change wire sttings on your loom plug, to configure to the new units. Tony
hi all,
i have plugged them in and they are doing some wired shit lol
thanks
