Guest mark escort cos Posted December 21, 2010 Share Posted December 21, 2010 Hi all I have a 2.0 EFI engine in the Cab. Issue is when i Connect the air flow sensor engine won't run, but without it is fine but runs a bit lumpy. Any suggestions ?? Im thinking of remobving the sanmco hose as per the pic and replacing with standard ford to see if it makes a difference. Quote Link to comment Share on other sites More sharing options...
