Guest fasteddy Posted August 18, 2010 Share Posted August 18, 2010 Hello peeps. Im upgrading my mk5b brakes and suspension setup as frankly its awful lol. at the moment it has standard brakes but as im going to be upping the power in the future to about 170bhp an upgrade will be needed. I was thinking about either a cossie conversion or st170 does anyone know which is easier/better? my suspension atm is lowered 60mm on just springs and 17" alloys. the ride is awful and it doesnt inspire confidence. what setups would people recommend? One last thing i live in basildon so i know elite is nearby but is there anywhere else that are good for this sort of stuff? Quote Link to comment Share on other sites More sharing options...
Guest planetrover Posted August 18, 2010 Share Posted August 18, 2010 well 17's and 60mm drop is your problem it will never handle nice for that you want 15' and 25 or 30mm drop and your shocks are probably duff from being 60mm down Quote Link to comment Share on other sites More sharing options...
gingergman Posted August 18, 2010 Share Posted August 18, 2010 just 17's is bad enough for ride comfort, so 60mm aswell must be well harsh, go with planetrovers advise for defo Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted August 18, 2010 Share Posted August 18, 2010 One of the brake conversions i always do/go for is fitting the st170 discs 300mm 4 stud discs with a set of mk3 mondeo calipers as the mondeo ones are also 300mm std on the full range apart from the top power versions narf cuts the cost of the conversion down from using the full st170 stuff, about £100-120 for all the bits you need on be-gay deliverd.... Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 18, 2010 Share Posted August 18, 2010 (edited) thanks for the help. does anyone have a particular make of shock/spring combination that works well? am going to be getting poly bushes too as mine are gone. i dont mind a firm ride but at the moment the front in particular has no give at all. i can push down on the front end and it barely moves although the back is quite soft (i think that is one of the reasons it understeers so much). Regarding the brakes are they a straight fit or do the calipers need spacing out or anything? Edited August 18, 2010 by fasteddy Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted August 24, 2010 Share Posted August 24, 2010 Regarding the brakes are they a straight fit or do the calipers need spacing out or anything? The calipers are almost a direct fit but you will need to put some 1mm spacers in (thin washers) and drill the hubs out with a 12mm drill as they have m12 mounting bolts not m10 like the std ones. Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 25, 2010 Share Posted August 25, 2010 ok cheers mate will get looking on ebay with regards to the suspension im gonna get it all checked over before upgrading as something is wrong it pulls all over the road and is very unpredictable. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted August 25, 2010 Share Posted August 25, 2010 you say you cabbie pull's all over the road it prob you lower wish bones are shot as these are common problem on mk5/6. Had same problem on most of my mk6's.Have been told you can get the arm's with poly bushes all ready in them.... hope this help's Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 26, 2010 Share Posted August 26, 2010 Thanks shaun I had a feeling it may be bushes gone and was gonna fit poly ones if that is the case. Do you know where i can get these wishbones from with poly bushes already fitted? I have also read it can be a gearbox mount gone or the diff so will probably still get it checked over first. Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted August 26, 2010 Share Posted August 26, 2010 Hi M8 If your upgrading your brakes and have'nt fitted "Braded Hoses" yet , then have a gander at www,brake-lines.co.uk they do "HEL" braded hoses with all s/s fittings and any colour covering to the braid and top spec'also, for about the same price of Bog Std' Goodridge hoses. Their also doing a good discount now and will also send you a tech'draw' of them if you ask. GGGGGGGreat people to deal with too... Also you might try ..mtsebc..for EBC Turbo Discs and Greenstuff ,Yellowstuff or really fast drive Redstuff....e-mail TONY you'll find him a great help....hope this may be of some use to you M8. (mtsebc on ebay# 350332610051) Rustler... The Oldest Cabbier..... Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 27, 2010 Share Posted August 27, 2010 cheers mate il have to have a look. was hoping to get a pair of st170 calipers tonight but got outbid at the last second lol Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted August 27, 2010 Share Posted August 27, 2010 Just looked on "Brake Lines" site ,their 10% disc't ends on 31st Aug,but their prices are still v/g. If you go to "mtsebc" site ..ebay..#..350332610051..you,ll see that their discount is the best avail, if you email Tony ,he'll give you the best prices for whatever discs or pads you want............lets know how you progress with your upgrade,there's a lot of us out here interested ......................... Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 27, 2010 Share Posted August 27, 2010 Ok will let everyone know how i get on. Still trying to get a pair of calipers first but as soon as i have them will be able to get a price for everything else needed. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 27, 2010 Share Posted August 27, 2010 I have a pair of ST170 calipers for sale. £100 plus postage avaiable if you need it. Surplus to requirements now as I bought a good car instead. The best thing to do is get new mintex discs and pads to go with them. There reasonable priced and should be fine for fast road use. Suspension wise your best off with a 30-40 drop with the 17's and a matched shock. The spax krypton gas units are what i've had before. There adjustable so wont be rock hard. Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 28, 2010 Share Posted August 28, 2010 Hi lee yes im interested in the calipers i dont get paid till next friday though so wont be able to have them off you till then if thats ok Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 28, 2010 Share Posted August 28, 2010 Just looked on the brake-line site. Does anyone know what lines i would need at the front, st170 or escort? Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted August 29, 2010 Share Posted August 29, 2010 Yea.. I had similar probs.with my '92 MK5 130bhp RQB engined cabby. I discovered that some escorts had as OE RS2000 brakes and other gear.Nobody seemed to know which bits were right for the car . I started with "Burton Power" page 122 ( they mention ST170 in their application chart)( You should get this info on their site)... the GOODRIDGE SITE may be of some help, and Brake Lines also have a application chart. If it were me I'd get my calip's and rotors fitted then take some measurements,note which fittings are required both ends,..then get back to Brake lines and ask for a few Tech Draw's for lines with similar spec' to your req'ts....I found them really helpfull.......Hope this may be of some use,sorry I can't be more specific,..."There's Got To Be" many other guys out ther who can be of greater assistance to you than me?.......the only thing youll lose out now is the 10% discount which ends on 31st Aug....but thats only 6quid or so Rustler .......The Oldest Cabbier.......... Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 29, 2010 Share Posted August 29, 2010 Thanks Rustler. The only problem is my cab is my daily drive and cant really afford to be without it while im sorting out what bits are needed. Unless anyone on here knows exactly what i need i will have to make a few calls and try and get everything needed before starting and hope it all fits lol. Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted August 29, 2010 Share Posted August 29, 2010 Yea...Gotyer... Thats a sod!!!....I've got an old bike or a pair of 1948 roller skates you can have.. Got to be somebody on here thats been down your "Conversion" road sometime.................You might try "Passion Ford"s site or FastFord etc,etc, someone there may be able to help. Have you gone right back to square "1" on our Brake & Suspension forum? Other wise it's got to be e-mails or phone calls to "Burtonpower and Brake Lines. Rustler ..The Oldest Cabbier.. Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 30, 2010 Share Posted August 30, 2010 Found a tutorial on here for fitting St170 brakes to a mk6 but not sure if mine are the same. If they are it says you need to fit spacers on the banjo union bolt (not sure what that is lol) other than that it all seems pretty straight forward and it looks like i can use escort brake lines. Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted August 30, 2010 Share Posted August 30, 2010 GGGGreat... sounds as if your on the right track now,.....try getting on to the "Profile" of the "TUTORIAL" guy and send him a private message or e-mail,.............Dont forget there are different B/Lines for nearly every MK and Model of escort, at least,.. according to both application charts. Had a short gander on the "Passion" forum, seems to be quite a lot on ST170' activity there............. Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted August 31, 2010 Share Posted August 31, 2010 Well iv rung burtons. They couldnt help but it looks like they will sell pretty much everything I need once I know what it is lol. Will wait now until I have the new calipers things might make a bit more sense then. I also have the added bonus that my clutch is going now too. the biting point is nearly on the floor lol. Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted September 3, 2010 Share Posted September 3, 2010 Well, at least a new clutch should cope with all that extra power,it's a good thing you've found out now,rather than later. Were you able to have a deal with LEE on his 170 calipers?.. Just a thought, have you requested a 2010 parts & accesssories catalouge, from "Burton Power", it's a bloody good source of info, reference, and a good read, and the best part .....IT'S FREE, just need to get on-line and submitt a request... Hope all go'es well from now on. Regards Rustler....The Oldest Cabbier... Quote Link to comment Share on other sites More sharing options...
Guest fasteddy Posted September 4, 2010 Share Posted September 4, 2010 I should be getting the calipers soon just waiting to see some pics first but should be all good. i have the burton catalouge there is a lot of stuff in there that i want lol. I need to try and find somewhere local who can supply and fit an uprated clutch, was thinking of giving it a go myself but dont want to risk being without my car. Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted September 4, 2010 Share Posted September 4, 2010 Hi Again The "Dreaded Clutch", ....../Had a problem wiyh my Kia Sorento clutch a couple of years back whilst We were in the UK I finally got it fixed under guarantee,.....BUT...whilst fighting King Kia ,spoke to a local .."Mr CLUTCH" depot. They were prepaired to replace the clutch with a H/D one that I could get sent over from GERMANY, far quicker and less expensive than anywhere else in Cornwall..................If your interested there's a depot in CHELMSFORD (0845078 3905) who'll fit a clutch or H/D one supplied by yourself from "BURTONPOWER" (no M8 I don't work 4 either of thers CO's or get commision) in Double Quick Time...give "Graham" a bell there ,might be some use to you......(NO Guarantee if you supply C/Plate etc) but u would'nt if you fitted it yourself !!!! Hope this might 'elp u M8.....Rustler...The Oldest Cabbier... Quote Link to comment Share on other sites More sharing options...
