Leaking Pump!
Guest KarlosG
Guest KarlosG
It seems my pump is leaking fluid as my carpet is wet with it and the pump has it in the underneath, is it common for them to leak and if so where from and can it be fixed?
Thanks!
Guest KarlosG
Both my rubber seals (big O-Rings) are intact but they look a little flat so probably need new ones.
Anyone know where I can get some?
