Temperature Gauge
Guest d33b0
Guest d33b0
hi my temp gauge has gone funny, i was driving normally the temp gauge was in the normal then all of a sudden it just dropped to the bottom of the gauge as is when the engine has been knocked off for some time,. when the ignition is on but not runing it wwill move to the start og the gauge markins but when running it no longer registers the engine temp.
any ideas pls cheers Tony
  • 3 weeks later...
Guest Paul Grainger
You have not said which model you have so i can't tell you where items are located.
If you can find the temp sensor then remove the wire and connect it to earth. switch on the ignition so the two red lights are on. The gauge should go all the way to the top. If it does then the sender is at fault, these are cheap and easy to replace by unscrewing from the head and screwing the new one back in, they are colour coded by the plastic insulator so replace it with one of the same type ore your gauge will be incorrect. If however the gauge does not go to the top, then is is probably a gauge fault, in this case it may be cheaper to get hold of a second hand instrument cluster. Good luck.
  • 2 years later...
Guest tazanddave
Hi Paul.we have a temp gauge that doesnt work.on a 90 mk4 efi.could this be fixed in the same way?
Edited by tazanddave
