Guest smegward Posted July 18, 2010 Share Posted July 18, 2010 after solving my relay problem i jump started it to get it started and since have lost a rear sidelight and my dash lights around the clocks but only them the battery lights etc all work but just the illuminating ones dont are these fused? or have a blown something beginning to lose my patience and scrap it now lol Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted August 10, 2010 Share Posted August 10, 2010 have a look in the door/flap of the fusebox for the symble or anything that could vagley resemble a light, they will more than likley be fused Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted September 3, 2010 Share Posted September 3, 2010 Sounds like you have blown a fuse. The sidelights have a separate fuse for each side, the no plate light and dash lights are also on one of them, i think it might be on the right circuit. From memory is could be fuse 6 or 7 but Ford in there infinate wisdom changed the fuse box configuration a couple of times so you will need to check with the fuse cover diagram. Good luck Quote Link to comment Share on other sites More sharing options...
