Guest Gregg Posted June 11, 2010 Share Posted June 11, 2010 Hi, I have just got my escort mk4 xri cab back on the road after 4 years. I took it out yesterday and the roof and windows have stopped working. Fuses look fine but that is as far as I could check as it was getting dark. Are both of these parts linked in same way or could this be a separate issue. I did try and listen for a click but nothing. Electric mirror work fine. Please help, G Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted June 13, 2010 Share Posted June 13, 2010 Hi Gregg, It sounds like an earth problem to me, check for power to the switches and if its there, then the earth could have corroded or come loose, if your at trentham and dont have it working by then, i will have a look at it for you.. Quote Link to comment Share on other sites More sharing options...
