Guest corrie Posted May 3, 2010 Share Posted May 3, 2010 hi just tried to see if the heated front screen works and when i switched it on the oil light illuminated on the dash when the switch was pressed then it goes out when i switch it off. any ideas anyone? Quote Link to comment Share on other sites More sharing options...
Guest corrie Posted May 7, 2010 Share Posted May 7, 2010 hi just tried to see if the heated front screen works and when i switched it on the oil light illuminated on the dash when the switch was pressed then it goes out when i switch it off. any ideas anyone? got to the bottom of this was problem with fuse box. i took it out for the second time and resoldered every contact and everything works now including my alarm. so i am now one happy bunny especially as i had bought some rs2000 clocks to go in. just loving the red clocks. Quote Link to comment Share on other sites More sharing options...
chaz Posted May 7, 2010 Share Posted May 7, 2010 Good to hear you got it sorted mate, feels good when you do iy yourself. Quote Link to comment Share on other sites More sharing options...
