Guest anton1 Posted April 15, 2010 Share Posted April 15, 2010 Wondered if anyone could help me? My fan wasn't kicking in when engine is running and I found a connection on top of the drivers front strut undone which I pushed back together. The fan now works but comes on constantly even when the ignition is on but without starting the engine? Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted April 15, 2010 Share Posted April 15, 2010 (edited) someone has bridged it! does your temp gauge work? its possible that it wasn't kicking in so the wires have been messed with. if you aren't too bothered about it kicking in when the temp says it should then wire a switch up to the wires you found. then put it on when you want. thats what mines like. i just filck the switch whenever stationary or if it seems to be getting hot. seemples. if you want it done right then im not your man, sorry Edited April 15, 2010 by s11pyk Quote Link to comment Share on other sites More sharing options...
Guest anton1 Posted April 15, 2010 Share Posted April 15, 2010 someone has bridged it! does your temp gauge work? its possible that it wasn't kicking in so the wires have been messed with. if you aren't too bothered about it kicking in when the temp says it should then wire a switch up to the wires you found. then put it on when you want. thats what mines like. i just filck the switch whenever stationary or if it seems to be getting hot. seemples. if you want it done right then im not your man, sorry Yeah was thinking that...I have removed an alarm you see and I've had to sort loads of wiring out. The washer jet was constantly on too but I've fitted a switch on the dash for that so suppose I'll do the same...just don't want it looking like an aeroplane cockpit! Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted April 15, 2010 Share Posted April 15, 2010 ha, aeroplane cockpit. if anyone knows how to make it so it comes on with the temp put it up here. i might even try fixing mine properly Quote Link to comment Share on other sites More sharing options...
