Guest djk Posted February 21, 2010 Share Posted February 21, 2010 I'm about to get the MK5 resprayed howevre before I do I'd like to replace the black trims on the outside of the windows, they have started to bubble under the black coating. Both front and rear. I'd also like to replace the rubber strip around the back edge of the boot. Don't know how to explain what the bits are, the window trims are the black (at least on my car they are black) bits that run along the top edge of the door skin between it and the glass. As I said I need all four, the two for the doors and two for the rear windows. The rubber trim is the strip that runs around the body work where the hood folds down, protecting the join between outter and inner body pannels, Hope this makes sense, David Quote Link to comment Share on other sites More sharing options...
