Guest GIZMO Posted January 28, 2010 Share Posted January 28, 2010 how do people,,well i need sum help again...i havent realy looked my self yet but thought id ask,,,me roof on my mk4 cab(1990 efi) has stopped worken,,,it did the other day,,but im getten nothing now,,,any ideas what the problem is,,, Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted January 28, 2010 Share Posted January 28, 2010 have you checked the fuses? then check the switches & connections make sure they are working failing that it could be the motor gone Quote Link to comment Share on other sites More sharing options...
Guest GIZMO Posted January 28, 2010 Share Posted January 28, 2010 ill check em first thing,,does the roof have a seperate fuse do you know?? Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 29, 2010 Share Posted January 29, 2010 it should have two green relays under drivers side dash, and two in the boot next to the motor, check the fluid while your there! Quote Link to comment Share on other sites More sharing options...
