Guest DEG Posted December 29, 2009 Share Posted December 29, 2009 Hi all, New to the escort world just bought a 1.6efi cabrio 1990 and ive noticed i few things wrong. 1/ when i put the roof up or down the motor carrys on its as if the switch sticks. 2/my heated front screen switch doesnt eluminate/or work. any advise would be great cheers david Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted December 30, 2009 Share Posted December 30, 2009 Hi The roof problems sounds like the switch is sticking or the relay is, try changing them. As for the front screen could be the switch or a fuse. Check the fuses first then try a new switch. Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted December 30, 2009 Share Posted December 30, 2009 (edited) I agree with the above, and generally find the switch sticks in a while when you first let go of it, i ended up replacing mine as it gradually got worse. As for the heated screen, does the screen actualy work ? if so it will prob just be the lamp in the switch, otherwise check as S6boy1979 has advised. Edited December 30, 2009 by Cabbytech Quote Link to comment Share on other sites More sharing options...
Guest DEG Posted December 30, 2009 Share Posted December 30, 2009 Cheers fella's it was the switch sticking so now on the look out for another, How do i test the screen? Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted December 30, 2009 Share Posted December 30, 2009 Cheers fella's it was the switch sticking so now on the look out for another, How do i test the screen? You will need either a multimeter or a test builb/light. Unplug the wires at the side of the screen, turn the screen on and test to see if you get a live feed, also there is an earth piont behind the clock/light in the middle of the roof. so remove it and make sure if you are getting a good earth. If this is all ok then it is either the switch or relay. Quote Link to comment Share on other sites More sharing options...
Guest DEG Posted December 30, 2009 Share Posted December 30, 2009 thanks s6boy1979 will have a test of stuff tomorrow Quote Link to comment Share on other sites More sharing options...
