Guest tadg Posted November 5, 2009 Share Posted November 5, 2009 hi all, can any one help? my rev counter will only show up to 3000 revs even at full bore, i have changed the clocks 3 times but still has the same faults, it seems ok at low revs and idel,?????????? cheers all tadg Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted November 5, 2009 Share Posted November 5, 2009 Hi, try putting the trigger wire directly to the 'W' terminal on your alternator, what Mk is your escort ? as i think the wire colour on the clock connector is different on the models. Quote Link to comment Share on other sites More sharing options...
Guest tadg Posted November 5, 2009 Share Posted November 5, 2009 Hi, try putting the trigger wire directly to the 'W' terminal on your alternator, what Mk is your escort ? as i think the wire colour on the clock connector is different on the models. hi, thanks for that, its a mk4 efi cheers tadg Quote Link to comment Share on other sites More sharing options...
