What To Do Next?
Guest charliem42
Guest charliem42
hi folks, ive hAD MY CABBY FOR 3 MONTHS NOW BUT ONLY THIS WEEK AM I GOING TO START USING IT, REASON BEING IT NEEDED TAX INSURANCE A BATTERY AS WELL AS MY DAILY HACK NEEDING TAX AT THE SAME TIME, ANYWAY NOW AND THEN I WOULD START IT UP IN GARAGE AND LET IT TICK OVER, BUT SOMETIMES I WOULD HAVE TO JUMP IT, SO A NEW BATTERY LAST WEEK, STARTED OK FOR COUPLE OF DAYS THEN BATTERY SEEMED TO E GOING FLAT SO I STUCK IT ON CHARGER AND STARTS AGAIN, BUT WHEN TAKING BATTERY OUT I COULD HEAR A NOISE WHICH TURNED OUT TO BE THE HEATER ON NUMBER 1 SETTING WHIRRING AWAY WITH NO KEYS IN CAR, SO YOU CAN PUT THE HEATER ON AND OFF WITHOUT KEYS SO HAVE YOU ANY IDEAS WHAT TO CHECK NEXT.
Guest bobatporty
My 93 cab fan motor won't run with the keys out.
I had a faulty ignition switch on a corsa I used to have that gave a live feed even though the ignition switch was off.
