No Brake Lights On My Mk5
Guest melvin210881
Guest melvin210881
Hi all have checked the fuses but nothing wrong with those just wondering if anyone else has had the same problem?
Cheers Marc
  • Admin
any other electrical problems front lights etc
you may need to replace the indicater and light stalk get yaself to a local breakers yard and change them over so it dont cost you too much money
regards ollie :biggrin:
Cheers Marc
as i said in the shoutbox m8 , its proberly your switch under the brake pedal, i have had quite a few that do the same, let me know if it is m8, cheers :wink:
Guest melvin210881
Thanks guys will try the brake switch, and i'm gonna get a new indicator stalk anyway as the damn thing doesn't self right after turning.
Will let you know if it works.
