Air Bag Light
Guest barclayrob
Guest barclayrob
Hi,
I have an N reg 1.8 Si Cabriolet and the air bag light keeps flashing !
Sometimes when the ignition is switched off and then on again thiis seems to be OK before starting up again later !
Can someone please tell me where the sensors are and whether this could be the problem ?
Thanks & kind regards,
barclayrob
Guest charlie74
probably the yellow connector under the front seats,, common fault, disconnect and then reconnect or give em a wiggle
Guest barclayrob
is there one under BOTH front seats charlie ?
please can you tell me where they are situated ?
BIG thanks,
Rob
PS seems to be worse when I drive as opposed to my wife - though it may be a 'weight thing', as I'm a big lad ?
Guest charlie74
more likely that you move the seat back mate,, its a yellow connector down by the door side of the seat or underneath on that side, both seats have them,, and they can work loose if the seats moved alot
which sounds likely in your case
  • 5 years later...
