Guest Alex-R Posted December 16, 2008 Share Posted December 16, 2008 hey all, couple of months ago, the fan stopped working, never came on since, any ideas? couldnt get seach to work, cheers! Link to comment Share on other sites More sharing options...
Guest neiloggy1 Posted December 17, 2008 Share Posted December 17, 2008 i have same problem on my cab got in 1 day heator wont work on any settings???? its a long process of elimination , first ,check fuses and relays then,check motor is working then,check switch is working then need to check u have a full 12v supply to switch,fusebox and heator motor check with a multimeter if any wiring is below 12v then like me im stuck here so i might take her to a garage unless some1 can help or if you sort your prob let me know cheers,neil Link to comment Share on other sites More sharing options...
Guest adamk Posted December 17, 2008 Share Posted December 17, 2008 (edited) My fan had stoped working, But my prob was at the fan motor its self. The brushes has worne down, and lost conection, I just tightend up the brush to the roter and it work fine now, was on a MK4 I ahve some pics someware, il rout them out Edited December 17, 2008 by adamk Link to comment Share on other sites More sharing options...
Guest adamk Posted December 17, 2008 Share Posted December 17, 2008 (edited) The gold colerd spring is were the brush is. have a look and see if its making contact properly to the roter, the big round silver bit in center of moter Edited December 17, 2008 by adamk Link to comment Share on other sites More sharing options...
Guest neiloggy1 Posted December 18, 2008 Share Posted December 18, 2008 cheers fella will try that this weekend wiring give me headache as i usually do mechanical side of things,keep ya posted Link to comment Share on other sites More sharing options...
