Interior Lamp With Map Lights
Guest pablomeadus
Guest pablomeadus
Hi
My interior lamp is not working off the door pin switches either on or off.
I can switch the middle roof lamp and both map lights on and off at there switches but no delay lamp function.
I've checked the door contact pins.
No fuses are blown.Should i hear a relay clicking?
It worked when i got the car about a month ago,but stopped a couple off weeks ago.
I had a quick look at the bulbs the other day,and replaced them.but,still not working off the doors.
I might have put the wires on the wrong way round though as they all fit on the same size terminals.doh.lol
Any help,which wires where or is the relay knackered?
Thanks
Pabs
Guest markeyboy
what mk cab have you got?
as far as i know (i may be wrong) the door switches are just a grounding point that is fron 0Volt side of the lamp,
try pinging the door switches, failing that clean up the earth for the switches
cant help you with the delay switch off tho (that may be through a relay for the timer)
