Elec Windows And Horn
Guest CHESSYDAVE
Guest CHESSYDAVE
ANYONE KNOW IF THERE IS ANOTHER FUSE OR RELAY ANYWHERE OTHER THAN THE ONE IN FUSE BOX
THE WINDOWS AND STOP WORKING AT SAME TIME :sad: :throw: PLEASE HELP
  • 1 month later...
Guest Cabbytech
Can you tell us where the earth had broken ? it might help other members in the future if they have the same problem or symptoms, many thanks.
Guest CHESSYDAVE
one earth inside drivers door and the horn was just a wire off at the horn
but in my quest to sort window problem i came a cross one more problem it the cluster of earth wires below passanger headlight under bonet they start to work lose cousin alsorts of problems with light diming when indicators are on
and have you ever had problems with rear light all comin on at once if so its just needs a earth to light unit
hope all this helps everyone just in case :biggrin:
