Guest CHESSYDAVE Posted November 2, 2008 Share Posted November 2, 2008 ANYONE KNOW IF THERE IS ANOTHER FUSE OR RELAY ANYWHERE OTHER THAN THE ONE IN FUSE BOX THE WINDOWS AND STOP WORKING AT SAME TIME :throw: PLEASE HELP Link to comment Share on other sites More sharing options...
Guest CHESSYDAVE Posted December 12, 2008 Share Posted December 12, 2008 sorted it was earth problem wire broken Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted December 13, 2008 Share Posted December 13, 2008 Can you tell us where the earth had broken ? it might help other members in the future if they have the same problem or symptoms, many thanks. Link to comment Share on other sites More sharing options...
Guest CHESSYDAVE Posted December 15, 2008 Share Posted December 15, 2008 one earth inside drivers door and the horn was just a wire off at the horn but in my quest to sort window problem i came a cross one more problem it the cluster of earth wires below passanger headlight under bonet they start to work lose cousin alsorts of problems with light diming when indicators are on and have you ever had problems with rear light all comin on at once if so its just needs a earth to light unit hope all this helps everyone just in case Link to comment Share on other sites More sharing options...
