Guest slmcmillan Posted April 13, 2008 Share Posted April 13, 2008 Hi got a bit of a problem i've got a mk5 cabby and it has a electic roof the only problem is that it doesn't work i've checked all the fuses and relays and noticed one of the fuses has blown i replaced the fuse and the ignition lights came on and when i started the car and when i turned it off the car was still running can any one please help cheers Link to comment Share on other sites More sharing options...
Guest gavbriggs Posted April 13, 2008 Share Posted April 13, 2008 YOU OBVIOUSLY TRIED IT WITH THE IGNITION ON BUT ENGINE NOT RUNNING? did the motor make a noise, if not try and get a multi meter on the elec connections and see if there is power to motor. that should show if its motor or power probs. Link to comment Share on other sites More sharing options...
