Guest no2lurch Posted July 9, 2007 Share Posted July 9, 2007 i have been thinking for a while about coverting my mk4 cab to zetec power. i dont want silly amounts of power, and want it as easy as possible as i am not the most mechanically minded. i have read tony's thread on zetec conversions and i have a few questions.... i am planning a 1800 zetec conversion as it seems easy, and as i am not planning to heavily tune the engine, i think there wont be much advantage over the 2.0 zetec. -i plan to buy a whole car so i can test the engine and make sure its ok. so can i just lift the whiole engine (complete with alternator etc) and bolt it to my cvh gearbox and stick it in? -i have a 1600 efi in my cab, so can i just extend the neccessary sensor wires instead of swapping looms? i know i will need the ecu though (a guy i know has done this, but he has no where finished the bodywork yet to take the car for a drive so need to be sure). -where is the best place to get the modded top mount from? Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted July 9, 2007 Share Posted July 9, 2007 1 you dont need to change ecu 2 what engine/car you thinking of geting escort or mondeo ? 3 top mount look on ebay Link to comment Share on other sites More sharing options...
Guest no2lurch Posted July 9, 2007 Share Posted July 9, 2007 i will probably getting an escort due to lack of space and cheapness. hopefully the 130ps engine, but maybe the 105ps version. i forgot to ask... will my current clutch be up to it? Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted July 9, 2007 Share Posted July 9, 2007 i would advise a escort as less to change ..... yes the efi cluch is the same as the efi depending on engine Link to comment Share on other sites More sharing options...
Guest no2lurch Posted July 10, 2007 Share Posted July 10, 2007 what about zvh? putting a zetec bottom end with the cvh efi head be a worth while consideration? if so, which botom end? 1800, 2000? Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted July 10, 2007 Share Posted July 10, 2007 zvh is the biggest waste of cash ever to do i think Link to comment Share on other sites More sharing options...
Guest no2lurch Posted July 10, 2007 Share Posted July 10, 2007 thanks tony for your help. a few last questions if i may please... -do i need to swap any of the ecu wires round? -i know the later zetec engines were slightly different to the early ones, but what year did they come in? -is it easier to do the swap by lifting the engine and box together or take the engine off the box and leave the box in place on its cross member? Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted July 10, 2007 Share Posted July 10, 2007 dont need to change any wires on the ecu ..... thay never put the late black top in the escort only the silver top wich is the one you wont we always put in throght the top engine and box bolted together Link to comment Share on other sites More sharing options...
