Guest jim_jamie Posted May 16, 2007 Share Posted May 16, 2007 im breaking a v6 mondeo mk2 and have all the bits possible to do it. the only part the worries me is the engine mounts and what gear box to use. i dont know if its been do before but if you have any ideas that may help please let me many thanks Link to comment Share on other sites More sharing options...
Guest Reid Posted May 16, 2007 Share Posted May 16, 2007 hey mate, welcome over to the cabby club im no use at all on this but sure some1 will be Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted May 16, 2007 Share Posted May 16, 2007 yes its been done ........ gearbox has to be the mondeo mtx75 ie the v6 box ...... and engine mounts will have to be custom ones what hubs and driveshafts would you use ? would you use the v6 engine manigment? Link to comment Share on other sites More sharing options...
Guest jim_jamie Posted May 16, 2007 Share Posted May 16, 2007 hi mate, the v6 is auto so will need another box, was gona use the managment iv got. any clues on the mounts? can i buy them anywhere? Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted May 16, 2007 Share Posted May 16, 2007 mounts you will have to find some then mod to fit ....good luck with useing the v6 loom hope your good at wireing if changing to manual you will need gearbox, flywheel, cluch, hydrolic releace bearing, hydrolic pipes and slave cilinder gearchange cable and gearchange ...... thats the small list to start with ..... bigest problem you will have is driveshafts Link to comment Share on other sites More sharing options...
