2.0 Zetec runs but wont idle.
Guest Lobsterboy
Guest Lobsterboy
Hi just put a 2.0 Silvertop into my Mk6 replacing a 1.8 which had a lack of compression on one cylinder. All went well and even started up straight away, but it wont idle.
everything was swapped over from my old engine to the replacement block and head but I cant see the extra 200cc would cause the lack of idle, can it? there also another mystery on the side of the coil pack holder is a small white unit which I cant find any details of - it has a two pin connector on it, however I can find a plug anywhere under the bonnet that goes to it, just a single wire close by with a non-factory female spade connector on it. Would this not being connected be the cause of of the non-idle?
Any help apricated
Terry
Guest Michaillel
Доброго времени суток [url=https://pamyat-39.ru/].[/url]
Ваш форум мне показался очень привлекательным и перспективным. Хочу приобрести рекламное место для баннера в шапке, за $1500 в месяц. Оплачивать буду через WebMoney, 50% сразу, а 50% через 2 недели. И еще, адрес моего сайта https://pamyat-39.ru/ - он не будет противоречить тематике?
Спасибо! Напишите о Вашем решении мне в ПМ или на почту zalevskija22201@gmail.com
