Passenger window not working mk4
Lee Hills
Hi  I am after some advice i cant get my passenger electric window to work , i have put a feed from the battery to the window regulator and that works have check the to see if i am getting 12 volts at the switch thats all ok have put a resistance test on the switch and that ok . I am at a loss . How is the regulator earth I can see the earth on the switch on drivers side but haven't got one on the passenger side is that correct
Guest Paul Grainger
Could be broken wires between the door and the a pillar. Pretty good place to look as that is where they flex from door opening. This can break them after a while.
Cheers.
