Cabriolet mk5 diagnostic port
Hi, depends on what gizmo you have got!
The two pin serial link is for the FDS2000 diagnostic PDU which was really dealer only kit back then. The three pin  plug is for the Star tester. Again dealer level but a lot more widely available.
This is the early level stuff before the standardised 16 pin DCL connector for EOBD which came out around 1995.
If you can find a Star tester then make sure it is a three digit one as you will need this one for the later EEC4 engine management module fitted to your car.
Might be easier to ask at your local dealer if they still have a Star tester!!!
If you do find one then code 111 is all systems pass
Hope this helps.
Cheers
Paul
Link to post
