Brettj123 Posted January 16, 2019 Share Posted January 16, 2019 Hi all I've recently brought my escort back to life after being a non runner for years (bought it recently as a project) but even though the car starts fine now after a new fuel pump, touching the accelerator even slightly stalls the engine. Engine restarts fine though, is it possible it's just a lot of crap in the fuel/air system causing this? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted January 19, 2019 Share Posted January 19, 2019 Hi, I would check for fault codes and check for air leaks. Make sure the fuel pressure regulator vacuum hose is connected. Cheers Quote Link to comment Share on other sites More sharing options...
