steve54 Posted September 6, 2018 Share Posted September 6, 2018 Hi, I have replaced the fuel pump and it works when connected directly to a power supply but totally dead when connected to the original wiring, I have checked with a meter at the contacts and it is also dead. Prior to replacing the pump I tested the electrics at the connection plug and there was power but the pump itself did not work hence the reason for replacing it, now there is no power to it. I read a few years ago about a separate pump relay located in the cockpit steering wheel area, I have looked and had a feel around but have come across nothing. Am I wrong in my thoughts or does anyone have a more accurate location for it? I have had a problem when searching for a replacement relay, does anyone know the correct part number, or any info please? Thanks in advance Steve - 1989 Escort Cabrio Tennis Quote Link to comment Share on other sites More sharing options...
steve54 Posted September 7, 2018 Author Share Posted September 7, 2018 Hi, An Update I have put the car on a ramp and with the aid of a mirror I can see a yellow relay and a green relay both about an inch square and a larger black box which I guess is also a relay with a black wire, 2 green wires and 2 brown wires going into it. Any info would be appreciated especially a part number would be great. Again thanks in advance Steve - 1989 Escort Cabrio Tennis Quote Link to comment Share on other sites More sharing options...
steve54 Posted September 7, 2018 Author Share Posted September 7, 2018 Update 2 I have removed the black relay and it is marked with the following no. 86 AB 12B 528-AA Does anyone know if this is the correct relay and is there anyway of testing it. Again thanks in advance Steve - 1989 Escort Cabrio Tennis Quote Link to comment Share on other sites More sharing options...
steve54 Posted September 13, 2018 Author Share Posted September 13, 2018 Update 3 I have since found out that the black relay is the cold start relay, so I am no further advanced in solving the problem, however some further information which hopefully may jog someone's memory in helping me solve the problem. A helpful person who had one of the black relays for sale informed me that it was the cold start relay and he was under the impression that the fuel pump relay was a purple one but when I looked under the dash again in addition to the black cold start relay I could only see a yellow relay and a green relay. According to the Ford Escort Owners Handbook the relay is located in position "V" in the main fuse box in the engine bay however this position is vacant in the Tennis Cabrio, having owned the car since virtually new I am confident that there was never one in this position. Has anyone had to change their fuel pump relay if so where did you find it and which one is it? Or any info would be helpful. Once again thanks in advance. Steve - 1989 Escort Cabrio Tennis Quote Link to comment Share on other sites More sharing options...
Ian71 Posted September 13, 2018 Share Posted September 13, 2018 Steve I have have a tennis , but feel helpless as I have not had these problems, but I will ask ask a old school ford mechanic tomorrow to see if he knows anything. Quote Link to comment Share on other sites More sharing options...
Ian71 Posted September 13, 2018 Share Posted September 13, 2018 I have had problems with earths to car body, worth checking ? Quote Link to comment Share on other sites More sharing options...
steve54 Posted September 25, 2018 Author Share Posted September 25, 2018 Hi Ian Thank you for your reply I will try a direct earth to the pump, do you know which of the pump plugs goes to the earth ie the white or the black plug? When I get a moment I will remove the drivers seat and see if I can get a better view ender the dash, so far I have been trying to see under there with a torch and mirror. Reading through some of the old forums some comments have referred to a purple relay which I have not seen under there but I can see a red socket at the far right of the bank I am wondering if that may be the one. I have a Haynes manual but cannot find a solution in there. Ho Hum the joys of an enthusiast. Steve Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted September 27, 2018 Share Posted September 27, 2018 Is the Tennis an MFI or EFI? Can't quite remember! The MFI cars had a purple relay which should be clipped to the steering column frame. The EFI cars had the relay in the fuse box. I think from memory they may have been yellow and square. Check the voltage across the pump when connected. It should be battery voltage for 1 second when switching the ignition on and then again when cranking. Cheers Quote Link to comment Share on other sites More sharing options...
steve54 Posted September 28, 2018 Author Share Posted September 28, 2018 Hi Paul Thanks for your reply, I have double checked as most info I have been given has mentioned the relay being under the dash which as you can see above I have been looking for which I think refers to an MFI, however I have just checked the original Ford Vehicle and Customer Service Record Assurance Certificate and it list's as Cabriolet Tennis 1.6EFI Steve Quote Link to comment Share on other sites More sharing options...
Ian71 Posted September 29, 2018 Share Posted September 29, 2018 Am surprised, all tennis cars I have seen are mfi, they seem to be registered between July and December 1989 Quote Link to comment Share on other sites More sharing options...
steve54 Posted September 30, 2018 Author Share Posted September 30, 2018 (edited) It was registered 01/08/89, for a semi layman is there an easy way of identification for MFI and EFI? Steve Edited September 30, 2018 by steve54 added mfi efi Quote Link to comment Share on other sites More sharing options...
Ian71 Posted September 30, 2018 Share Posted September 30, 2018 The inlet manifold bolted on the back of the engine shows Efi stamped in big letters on the front, and also mfi will have a distributor cap on the right hand side of the engine, efi has a coil pack instead. Have you got a Haynes mk4 manual ,it’s like a bible for cars and shows you lots of close ups of parts, well worth buying one. We alll had to start somewhere as you are doing now. Quote Link to comment Share on other sites More sharing options...
steve54 Posted October 8, 2018 Author Share Posted October 8, 2018 Thank you all for your replies and thanks Ian for info to help clarify the engine, despite the original ford purchase paperwork which says it is an EFI it does have a dizzy on the right and FORD on the manifold so it is the MFI. I do have a Haynes manual "Ford Escort (petrol) Sept 1980 to Sept1990" which cover 1117cc to 1597cc it does not cover RS1600i or revised Escort range Sept 1990. Is there a better or more appropriate manual. I have worked out the brown lead to the pump is the earth, so I will try a direct earth lead connection and see if that works which at least will show if there is a earth connection fault. I have also noticed there is a thin tube/hose that goes up inside the wheel arch to a small box like item adjacent to the fuel filler that is not connected as the connection is broken, I have looked in the manual and cannot identify what this is does any one know? Thanks again as the saga continues. Steve Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted October 12, 2018 Share Posted October 12, 2018 Steve, I know you said the wiring was dead going to the pump but it could be the live or the earth. Put your meter across the pump wires (with it connected) and test the voltage when it should be running i.e. when you first switch on for 1 second or when cranking. You should have battery voltage. If not then try it again with the probe that was on the earth wire now going to a known good earth (even if it means running a wire back to the battery). If you now have battery voltage then it is the earth at fault. If you still don't then it is the feed. At least then you will know what side of the circuit to investigate. Cheers Paul Quote Link to comment Share on other sites More sharing options...
steve54 Posted October 12, 2018 Author Share Posted October 12, 2018 Thanks Paul, It was my next intention to try it with a direct earth to the battery. You mention to test it whilst cranking, does that mean it bypasses the relay and creates a direct positive to the pump whilst cranking? Steve Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted October 13, 2018 Share Posted October 13, 2018 The relay should start the fuel pump running when the engine is cranking. On Mfi Escorts the purple pump relay was a very common fault so if providing an additional earth does not fix it I would be looking at the relay. Cheers. Quote Link to comment Share on other sites More sharing options...
steve54 Posted June 2, 2020 Author Share Posted June 2, 2020 I thought you are overdue an update, I eventually found the correct relay and it was as said in the suggestions under the dash tucked right out of the way (not being a contortionist it did take a while to get to it) I replaced it and all works fine. Quote Link to comment Share on other sites More sharing options...
steve54 Posted August 26, 2025 Author Share Posted August 26, 2025 It has been a while since i last started the car and have once again hit the problem of not starting again. I have just replaced fuel and air filters and tried with a dose of quickstart with no success, and the plugs spark ok so it is going back to check everything again from last time. I still notice that the little box in the rear wheel arch near the fuel filler with the thin tube is still unattached as the joint is broken the box is attached but the tube is not. Does anyone know what this is for and how important it is, what is it called so I can try and get a replacement as I cannot find a mention of it in the Haynes manual? Steve Quote Link to comment Share on other sites More sharing options...
