Escort Mk 6 Cabby Heated Front Windscreen Issues
ELK100
Hi, This is my first post so I hope someone has come across a similar problem? I upgraded my front windscreen of my 1996 cabby ghia to a heated front windscreen. All worked well until recently when the switch light came on very briefly then went off. It continues to do this when the switch is depressed and there's no front windscreen demisting. The switch is not at fault as I've changed it for the one in my Ghia X that I know works. I don't think its the relay as I've swapped that as well. I've disconnected all the plugs and sprayed them with wd40 in case there's dampness present. So I'm at a bit of a loss. Any suggestions anybody?
Guest Paul Grainger
Time to get the multimeter out!
Does the relay click? That will tell you which side of the relay is faulty.
