Guest Deano1 Posted March 17, 2017 Share Posted March 17, 2017 Just a quick question Anyone Broke a Camshaft in Half? if so what else did it damage? Quote Link to comment Share on other sites More sharing options...
Guest username Posted March 17, 2017 Share Posted March 17, 2017 (edited) Wow, not on a CVH no! How on earth did that happen? Bought a Xantia with a snapped camshaft and the bottom end was fubar, bent rod & all and those old XUD's are supposed to be bulletproof! I'd imagine you'll have at least a couple of bent valves, maybe damaged lifters/rockers and cam journal damage in the head but I would also want to strip the bottom end and make sure the rods & bearings haven't been compromised (as well as being easier to clean up any valve imprints on piston crowns without getting swarf in the engine). Would love to see some pics of the damage, sounds hardcore! hope it's not a pain to fix Edited March 17, 2017 by username Quote Link to comment Share on other sites More sharing options...
Ian71 Posted March 17, 2017 Share Posted March 17, 2017 Was it a standard Ford camshaft or a piper or similar high lift camshaft ? I had a Kent cam in my fiesta rs and two lobes disappeared leaving me with an engine rebuild. Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted March 18, 2017 Share Posted March 18, 2017 Only seen it on a diesel. Caused by piston/valve contact due to timing belt failure. Never on a CVH. Quote Link to comment Share on other sites More sharing options...
