AMC Posted February 23, 2017 Share Posted February 23, 2017 Hello All. I have been experiencing this problem for over a week engine juddering at low revs increase the revs and the problems disappears, I have changed all of the leads distributor and cap rotor arm module supply lead to module and ignition coil check the pump relay any suggestions!!!!! Quote Link to comment Share on other sites More sharing options...
jinks Posted February 23, 2017 Share Posted February 23, 2017 fuel starvation Quote Link to comment Share on other sites More sharing options...
AMC Posted February 23, 2017 Author Share Posted February 23, 2017 Fuel pump of filter?? Quote Link to comment Share on other sites More sharing options...
AMC Posted February 23, 2017 Author Share Posted February 23, 2017 Also there are mo problems on tick over engine not cutting out. Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted February 25, 2017 Share Posted February 25, 2017 Spark plugs? Quote Link to comment Share on other sites More sharing options...
AMC Posted February 25, 2017 Author Share Posted February 25, 2017 Hello Paul. Nope new set pf plugs fitted. Quote Link to comment Share on other sites More sharing options...
jinks Posted February 25, 2017 Share Posted February 25, 2017 is it efi chap Quote Link to comment Share on other sites More sharing options...
jinks Posted February 25, 2017 Share Posted February 25, 2017 if so clean the icv they get chocked up also look at fuel pipes there not squashed can you smell on fuel when on idle with the bonnet up and running Quote Link to comment Share on other sites More sharing options...
Ian71 Posted February 25, 2017 Share Posted February 25, 2017 Check them vacuum pipes around the inlet manifold to see if there any leaks,they run a bit rough if those pipes are leaking AMC 1 Quote Link to comment Share on other sites More sharing options...
AMC Posted February 25, 2017 Author Share Posted February 25, 2017 Hello Jinks it's the MFI mate. Quote Link to comment Share on other sites More sharing options...
AMC Posted February 25, 2017 Author Share Posted February 25, 2017 No smell of petrol with the bonnet up. Quote Link to comment Share on other sites More sharing options...
AMC Posted February 25, 2017 Author Share Posted February 25, 2017 Vacuum pipes are okay will check again tomorrow engine running sweetly on idle. Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted February 26, 2017 Share Posted February 26, 2017 I have heard they used to get problems with the fuel metering head. The metering pin sticks. Quote Link to comment Share on other sites More sharing options...
AMC Posted February 26, 2017 Author Share Posted February 26, 2017 Hello Paul Where about's are the metering pin sticks? Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted February 27, 2017 Share Posted February 27, 2017 The pin is in the metering head where all the fuel pipes come from. Undo the clip and remove the air intake hose. Under that you will see a plate which lifts up as the air goes into the intake. The more you open the throttle the more air goes in and the more the plate lifts. The pin is on the end of the plate and adjusts how much fuel is injected. Sometimes they stick and under fuel. You can lift the plate by hand but treat it with care as it is very sensitive and easy to damage. Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted February 27, 2017 Share Posted February 27, 2017 Hi, Google bosch k jetronic fuel distributor. Plenty of diagrams to look at. It is the control plunger that sticks. Quote Link to comment Share on other sites More sharing options...
AMC Posted April 14, 2017 Author Share Posted April 14, 2017 Evening all. Took the motor to Grove Garage Brentwood Essex turns out it was split in the air induction hose between the throttle housing and the air sensor plate every time I pulled away the hose opened due to slight engine movement losing the vacuum an therefore power and closed after the engine returned to its original position. Thank you for your suggestions should have made a more through check of the hoses " you live and learn" Regards Stan. Quote Link to comment Share on other sites More sharing options...
Ian71 Posted April 14, 2017 Share Posted April 14, 2017 Yea I said that back in February,they perish,I ad the same on mine. Glad it's cured. Quote Link to comment Share on other sites More sharing options...
AMC Posted April 15, 2017 Author Share Posted April 15, 2017 Ian. I should have taken the hose off completely and done a visual check would have saved a lot of time and a few quid lesson learned drove car back from Grove Garage located in Romford Essex lovely and smooth now pleasure to drive. Quote Link to comment Share on other sites More sharing options...
Ian71 Posted April 15, 2017 Share Posted April 15, 2017 That's great news,if you live in Essex why not meet us all at a battlesbridge show ,we do 3 there ,the best one is the all Ford show beginning of august,you will be made very welcome,condition of car is not important. Regards Ian. Quote Link to comment Share on other sites More sharing options...
AMC Posted April 23, 2017 Author Share Posted April 23, 2017 Will have to get out to some Ford meets spent years do Mini meets in the Mrs motor when is the battlesbridge event Ian. Quote Link to comment Share on other sites More sharing options...
Ian71 Posted April 23, 2017 Share Posted April 23, 2017 Look at events m8, there are a few shows in the next few weeks , three in Essex ,one in Bromley , and large shows at Santa pod and silverstone. Take your pick,you will be made welcome. Quote Link to comment Share on other sites More sharing options...
