Guest Springy2112 Posted February 6, 2017 Share Posted February 6, 2017 Its ok Paul The adjusters are working perfectly I checked them again ...I have the brakes working ..after doing a normal bleed on Friday pm with my work mate on the pedal I managed to extract more air from both rear lines..now just need to bed in all the new mating surfaces. Cheers.. Quote Link to comment Share on other sites More sharing options...
Nick Barnes Posted February 9, 2017 Share Posted February 9, 2017 Glad to hear you've sorted it Quote Link to comment Share on other sites More sharing options...
Guest username Posted February 10, 2017 Share Posted February 10, 2017 Wow that was some stubborn air! Reminds me of replacing a clutch master on a mate's Merc C180 a few years ago, had to leave that gravity bleeding for a whole day before getting anything like a decent pedal! Glad to hear it's on the mend now though, and unlike some you haven't just decided that old Escorts have bad brakes lol. I'm the same with the EFi system, I WILL make it work well with the CVH engine! Quote Link to comment Share on other sites More sharing options...
Guest Springy2112 Posted February 11, 2017 Share Posted February 11, 2017 Thank you all for you support its been a real grueller...I was determined not to be beaten ..I had various mk3 s in the eighties and nineties and never had issues making the brakes work..OK they'll never be as good as my other 3 cars (modern stuff) but I knew they were not to right even by 1984 standards... Any way on to other bits now... Had 4 new tyres fitted and I am in the throws of trying to get audio sorted but that's on the audio thread..wish me luck.. Thanks again....Paul.. Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted February 19, 2017 Share Posted February 19, 2017 Hi, have you replaced the adjusters in the rear drums? These are prone to wear and slip as soon as you apply he hand brake. This will then give you loads of travel on the foot brake. Cheers Quote Link to comment Share on other sites More sharing options...
Guest Springy2112 Posted February 19, 2017 Share Posted February 19, 2017 Hi Paul yes the adjusters are new and working properly...the brakes are done it was air hiding in the lines..Cheers buddy Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted February 26, 2017 Share Posted February 26, 2017 Are the rear adjusters ok? They can slip when you put the hand brake on giving you loads of travel. Quote Link to comment Share on other sites More sharing options...
Guest Springy2112 Posted February 27, 2017 Share Posted February 27, 2017 Yes re above they are new and adjusted properly the brakes are done and fine now Cheers.. Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted February 27, 2017 Share Posted February 27, 2017 Rear adjusters are ok are they? When they are worn they slip when you put the handbrake on giving you a load of travel on the foot brake. Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted February 27, 2017 Share Posted February 27, 2017 Ahh sorry about the reposts. Couldn't see them and didn't realise there was a second page!! Glad you got it sorted. Quote Link to comment Share on other sites More sharing options...
Guest Springy2112 Posted March 1, 2017 Share Posted March 1, 2017 No worries Paul I appreciate everyone's help advice and support ..thanks again Quote Link to comment Share on other sites More sharing options...
Himanshu Posted May 12, 2017 Share Posted May 12, 2017 The seals in the master cylinder are the culprit I suspect. These give the age of the car and especially if you have bought a second hand one, The rubber perishes over time. Many times a refurbished master cylinders are very poorly built. Unfortunately do the age and Ford not manufacturing these, a refurbed on or second hand one is the only way, but just put new seals in. On average you will probably have to change the seals bi-annually. The same as manual power steering racks. My old rack covered 100k, lasted 25 years. I bought reconditioned racks only to have it fail ever two years. Somethings you have to throw money at. Unfortunately it is getting to the point you cant even throw money at these parts as Ford simply don't make them. I have purchased from Kelly Bray and Burton Power and unfortunately the new replacements don't fit or a tonne of work need to be done to modify it to ge it to fit, or they are so poorly refurbished that they last a minimal period. The labour costs out weigh the price of the components Quote Link to comment Share on other sites More sharing options...
