Guest escortfan Posted March 5, 2016 Share Posted March 5, 2016 hi to fellow members.does anybody know why my immobiliser red light comes on when i lock the passenger door ,but not when i lock the drivers door? i've got a 1.8si cab 1995. many thanks Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted June 19, 2016 Share Posted June 19, 2016 There is a switch around the door lock on each side which arm and disarm the alarm when the door is locked and unlocked. It could be that the one on the drivers side is faulty. Testing it is easy. Open the bonnet and bounce the alarm switch quickly about 10 times and the alarm horn should chirp once. Then go around the car opening and closing the doors and operating the locks. Each time you should hear a chirp from the alarm, if not then the control unit is not receiving a signal from that switch. To exit test mode then just leave it alone for about 30 seconds and it will chirp twice. This is self test mode exiting. Hope this helps. Quote Link to comment Share on other sites More sharing options...
