Why Is My Drivers Side Window Sticking Out At The Top?
Guest Adsxr3icab
Guest Adsxr3icab
Sorry if this is in the wrong section but I'm new and learning so bear with me, anyway can anyone help me I've tried adjusting my window but it has no adjustment I can see to bring the window nearer the car? When I get out I have to push my window under the seal but obviously I can't do that from inside lol please help it's a mk4 xr3i cabby cheers Adam
Guest Adsxr3icab
Thanks I'll try that then, now I have even more problems on the way home my cabby has started knocking but only on de acceleration I'm think steering column as I know my bushes need doing.
There is an adjustment screw around the middle of the door, you have to remove the panel to access it. From memory, it limits the vertical travel of the window assembly.
Guest Adsxr3icab
Thanks andya I've tried that I fact I adjusted both screws window height and angle made abit of difference but not much any more ideas thanks guys I really appreciate it
You could try and move the top of the quarter light inwards. From memory, it's attached to the door frame at the bottom. If you loosen the bolt, there should be a little adjustment in and out. Remember to have the window lowered as you push the quarter light frame in, to avoid the risk of breaking it. Failing success with that process, you could always try a little subtle brute force on the quarter light, but you would have to remove the quarter glass, fiddly.
Good luck,
Andy
If there is about 2-3 cm before it reaches the top you would not get it any further up. If you can take your hand and push it up further, then it means the top teeth on your window regulator is worn. So when the window reaches this height, the gear on the window motor can no longer grip it.
The cause of wear on these is due to the window being pushed against the top of the roof frame every time you open and close the door. Many newer cars tend to move the window up about 2 seconds after the door is closed and also lowers it by around 2-3 cm every time you open the door. It is like this on BMW E36, E46, E92 etc. Audi A4 convertible.
  • 10 years later...
  • 3 weeks later...
  • 4 months later...
This is a really common issue with cabriolet windows and the advice here is spot on. From what’s shared, it seems like it could be related to roof alignment, worn regulator teeth, or needing adjustment inside the door panel . These small alignment problems can make a big difference in sealing and comfort. It’s always worth sorting these early to avoid bigger fixes later. Just like planning a smooth journey, even something like booking a chesham to luton airport taxi ahead of time helps avoid last-minute hassle.
  • 2 weeks later...
On 08/12/2025 at 16:59, Rise Dentistry said:
Car window issues can be really frustrating, especially when they affect your daily drive. It’s always helpful to understand the possible causes before heading to a mechanic. On road trips, having comfortable stops like RV Parks Midland TX makes dealing with little car troubles a lot less stressful
Car troubles are never convenient, but planning comfortable travel stops definitely helps reduce stress. Exploring opportunities like Mexican citizenship can also make future road trips and travel experiences easier.
