Guest Zanhar25 Posted September 12, 2015 Share Posted September 12, 2015 One of the last jobs I've got to do is repair the rear heated window. I've had several attempts at this and it's driving me made. When you push the switch you hear the really "click' but nothing happens, the light on the switch doesn't come on. Things I've changed, checked, 1 changed grey relay twice last time with a brand new one! 2 changed switch but the old one checked out OK even the green And yellow LEDs worked with a battery connected. 3 heater element checked with resistance meter, all ok 4 fuse 27 ok and has 12v on it 5 fuse 11 ok and has 12v on it with ignition on. Does anyone have any ideas what else to check. Any wiring diagrams available for the heated rear window circuit? Any advice greatly received Thanks Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted June 19, 2016 Share Posted June 19, 2016 Have you got voltage at the window? Haynes manuals are pretty good for wiring diagrams. Quote Link to comment Share on other sites More sharing options...
Guest nicholas huntley Posted June 19, 2016 Share Posted June 19, 2016 Check continuity of screen heater element. Often a damaged/broken/burnt wire in the screen will affect the 'on' warning light as there is no power going through the screen to activate the light. You should be able to measure current at the wires going to the connectors on the screen, 12 volts of course, without a tester connect wires to a 12 volt bulb, bulb should light with screen switched on. If no light, fault must be switch end or broken/cut wire, assuming fuse is OK. Quote Link to comment Share on other sites More sharing options...
