Guest Joe35 Posted July 31, 2015 Share Posted July 31, 2015 Does a Mk4 mfi have a idle control valve? Quote Link to comment Share on other sites More sharing options...
welshlad Posted July 31, 2015 Share Posted July 31, 2015 yes should be near driver side strut top or on the left hand side of the throttle body Quote Link to comment Share on other sites More sharing options...
Guest Joe35 Posted July 31, 2015 Share Posted July 31, 2015 Cheers, another question, if the icv is loose could that be the prob? Quote Link to comment Share on other sites More sharing options...
welshlad Posted July 31, 2015 Share Posted July 31, 2015 whats the problem, which one have you got? the one on the strut or the other one? doesnt really make a difference. carb cleaner is the best thing to use to clean it out if your thinking about taking it off/apart (easy job) Quote Link to comment Share on other sites More sharing options...
Guest Joe35 Posted July 31, 2015 Share Posted July 31, 2015 It's the one by throttle body, ill take it off a clean it, cheers for your help Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted July 31, 2015 Admin Share Posted July 31, 2015 have you got a pic please joe :>) I thought the efi had the iscv  Ollie Quote Link to comment Share on other sites More sharing options...
Guest Joe35 Posted August 1, 2015 Share Posted August 1, 2015 Your not wrong I was looking at something completely different under the trottle housing,I read up and the MFI dosent have one, so could the prob be the mixture of fuel and air so just a air leak? Quote Link to comment Share on other sites More sharing options...
Guest Keith Whitbread Posted August 2, 2015 Share Posted August 2, 2015 If it helps, I had a problem with my MK5, kept stalling and stopping. There was a carbon build up in the inlet manifold that blocked part of the butterfly. The problems was due to a leaking value, ended up in a complete engine rebuild? Keith Quote Link to comment Share on other sites More sharing options...
welshlad Posted August 2, 2015 Share Posted August 2, 2015 Sorry i didnt read your post properly i thought i seen efi not mfi lol Quote Link to comment Share on other sites More sharing options...
Guest Joe35 Posted August 3, 2015 Share Posted August 3, 2015 It doesn't want to be carbon build up can't afford a rebuild, there an easy way of checking that out? Quote Link to comment Share on other sites More sharing options...
