Guest bantamboy Posted March 4, 2015 Share Posted March 4, 2015 my power hood seems to work when it wants to todayi have been trying to sort it out the fluid level is correct but sometimes it works sometimes it doesn't also when it does work it works with the ignition on.i thought it should only work in position one could it be down to a faulty relay or the pump Quote Link to comment Share on other sites More sharing options...
RScab Posted March 4, 2015 Share Posted March 4, 2015 What Model Cab m8 Quote Link to comment Share on other sites More sharing options...
Guest bantamboy Posted March 4, 2015 Share Posted March 4, 2015 hi its a 1997 1.8 ghia mk6 also in case I have to remove the pump how do I get the hydrolic pipes off the pump cheers Quote Link to comment Share on other sites More sharing options...
Guest bantamboy Posted March 8, 2015 Share Posted March 8, 2015 hi all ive been messing around with my cabbys roof today it seems that if I disconnect the live and earth wires going to the pump and wire straight to a spare battery I have the roof works fine as soon as I wire it back to how it should be it only works when it wants also when it does work it the ignition is on could it be the switch or one of the 3 relays advice would be very helpful many thanks Quote Link to comment Share on other sites More sharing options...
Guest bantamboy Posted March 11, 2015 Share Posted March 11, 2015 roof now sorted bad connection just need the fliud resovior pot Quote Link to comment Share on other sites More sharing options...
