Did 90Spec Have.....
Guest GINGExR2T
Guest GINGExR2T
Does anyone know if any of the 90 Spec 3i's came with a fuel computer??? reason is I'd like to fit one to mine and if they were fitted there will be a diagram somewhere :-)
Cheers
Ginger
Guest GINGExR2T
Sorry, I should have said EFi.
Kenny, Was yours MFi or EFi?????
Ginger
Guest GINGExR2T
Cheers ken, All sorted now, the 90 spec loom does have the required wiring,yellow plug (5 pin D shaped plug [plug is tapped up], same as the one's that feed the door wiring) located behind the clocks just below the bottom right hand corner of the wind screen, and a black plug (same type as the spot lights plug) under the rear seats. Only a few wires to add into the loom but looks easy enough, Just need to find the removable part of the loom that unplugs from the yellow D plug that goes to the fuel computer to save me making one up.
I've checked 3 other looms MFi turbo and non turbo and the yellow plug looks to be standard in all looms 3i and turbo MFi and EFi.
Ginger
Edited by GINGExR2T
