Fiesta Rst Engine Numbers
welshlad
Hi all
Anyone know what numbers are stamped onto a Fiesta RS Turbo Block and Head?
Gonna buy one that needs a bottom end rebuild but i wouldnt know the difference from one from a EFI 3i engine!
Its the block and head im buying with efi, injectors etc no turbo with it tho :sad:
Edited by welshlad
Dunno mate on codes. But i've got a escort rs turbo engine for sale that needs a new head gasket and a freshen up. Blown between cylinders 1 & 2 so still runs and holds all fluids. Also have a rebuilt one but its been sitting for 2 years. May require a partial strip and lube up of bearings to make sure it run ok when started. I replaced all seals, belts and oil filter in preparation for fitent to a friends car but that never happened
Got the whole setup but on mfi.
Turbo is a hybrid item. I've only used it for a around 2000 miles at most and I got it new. Its not water cooled which is a bonus as the exiting hot water superheats the cooling system on these cars. Turbo is £300, rst engine £200, Rebuilt one £450. Engine was pushing around 200bhp.
Also got loads of tuning parts for these cars. Intercoolers, Alloy rads etc
Got to be efi :sad: easy loom wise etc i might need some other parts of ya if i get the engine as it will need a turbo, rst2 manifold and water resorvoir etc etc basically whatever i need to chuck it in my engine bay :smile:
Nevermind i forgot to bid it started at £100 and went for £105 gutted :sad: was near me to and the same town were my car originally lived only needed big end bearings bargain whoever won it
