Roof Problems
Guest roy1972
Guest roy1972
I've just brought myself a mk4 convertible escort I've never had one before it's a power hood without the battery on I folded the roof down no problems when putting it back up the bar above the roof didn't move so the rear window was sagging down and above the front doors there is a dip in the roof any ideas please
Someone has had the roof of seat belts are on the rear seat how and were do these fasten too thankyou for any help Roy
Guest roy1972
Yes as soon as I can get the cover of the car I will take a few pictures. What a brilliant site and thankyou for the reply and the welcome
Guest roy1972
Yes ollie 500se trim drivers side door card missing I've got it up for sale on eBay m8 as I've just brought half leather recaro for it I've also put a rs turbo lump in it can not post pic it say file to big m8
you have to turn the t piece on the roof motor to use it manually.
the roof is easy to remove, 3 bolts both sides behing the rear door cards and the cable that runs around the base has a small nut each side, oh and a few odd screws holding the inner lining in place!
Guest roy1972
Yes I know about the t piece on the pump its not the folding down it's putting it up if you read the first thread you would now what I am on about
Guest Lee81
When the roof has been off the car part of the rear frame can often get stuck leaving a big sag in the roof by the rear window.
Undone the roof at the front then go inside the car and force this section out.
If it won't stay in place then you may have damaged straps or frame which would probably cause similar issue.
Need pics to give more accurate advise. Upload them photo bucket or resize to under the file size for this site
Near the rear shelf were the rooflining side trim is, put your hands up the sides and above the lining and feel for the roof bars then push them forward, i had the same problem after refitting mine, after a few open and closes it sorts its self out :smile:
you might have to do it once more maybe , i did and then it sorted itself out, think it just gets stiff or if it doesnt work then as RSCAB said then there could be summat damaged or bent ... hopefully not tho :smile:
