How To Remove Top Half Of Rear Seat
Guest big g
With the roof up u will see it as a cloth back pull this back and you will see two bolts on each side it then slides up out of place I know I have just discovered the previous owner left them out on mine so I would be interested to know what size they are hope this helps mark
Guest Kelly Jeffery
you pull the release in the boot then they have hinges in the bottom corners held in with bolts
hope this helps
Guest big g
hope this helps
its the top half that's attached to the body I need to know
rest of the interior is out
