Guest raider975 Posted February 16, 2012 Share Posted February 16, 2012 i have fuel going to the pump but no fuel going to the fuel injectors Quote Link to comment Share on other sites More sharing options...
RScab Posted February 16, 2012 Share Posted February 16, 2012 What Model & year m8 Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted February 17, 2012 Admin Share Posted February 17, 2012 Can you hear the pump running? Quote Link to comment Share on other sites More sharing options...
Guest raider975 Posted February 17, 2012 Share Posted February 17, 2012 hi yes the pump is runing Quote Link to comment Share on other sites More sharing options...
Guest raider975 Posted February 17, 2012 Share Posted February 17, 2012 i think the car is 1987 or 1988 Quote Link to comment Share on other sites More sharing options...
RScab Posted February 17, 2012 Share Posted February 17, 2012 i think the car is 1987 or 1988 EFI ??? Quote Link to comment Share on other sites More sharing options...
Guest raider975 Posted February 22, 2012 Share Posted February 22, 2012 cvh engine Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted February 22, 2012 Admin Share Posted February 22, 2012 EFI ??? should be mfi unless had engine change was efi 90 onwards den could be metering unit playing up Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted February 22, 2012 Share Posted February 22, 2012 Are you sure there is no fuel at all coming from the injectors. Removing one at a time and placing in a jar will establish this. Turning the engine over should fire the injector. Work your way back down the fuel system from there. My thoughts are you could have a air leak on intake hoses. Blocked fuel filter or fuel pipes. Or the fuel pump isn't running full time in which case the pink relay is playing up which is the most common. Quote Link to comment Share on other sites More sharing options...
