Guest Gruff Posted October 4, 2011 Share Posted October 4, 2011 My central locking has stopped working on both doors on my mk4, any help and diagramswould be appreciated as I'm not really mechanically minded Quote Link to comment Share on other sites More sharing options...
Guest dazzersrst Posted October 4, 2011 Share Posted October 4, 2011 check the fuse Quote Link to comment Share on other sites More sharing options...
Guest Savage Posted October 4, 2011 Share Posted October 4, 2011 I know it sounds silly, but have you tried using another key. I had that on my 5b. Turns out the red key had stopped working correctly but everything worked ok with black for some reason. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted October 4, 2011 Share Posted October 4, 2011 if both have stopped working check the fuse in the fuse box think's it a yellow 20amp, if thats fine check the wire going between the door and pillar on driver's door these have been know to snap. Also there is a plug up by the kick panel on driver's side check it haven't come apart Quote Link to comment Share on other sites More sharing options...
Guest Gruff Posted October 4, 2011 Share Posted October 4, 2011 ok I'll check those thank you Quote Link to comment Share on other sites More sharing options...
