Mark 4 Misfire
Guest lextrojan
Guest lextrojan
got a mark 4 replaced head gasket,new cam,new valves new fuel filter,new coil plugs n leads & a new sensor in the inlet manifold its still running like a bag of nails .can anyone help
Guest El87cabi
Without knowing which mk4 you have we'd all be clutching at straw's, there are many variants, give us the year, a detailed description of what the car does and doesn't do, a decent pic of your engine bay wouldn't hurt if ur unsure which particular mk4 you have.
All the best, el
Guest lextrojan
thanks for replying ..its a 1990 model 1600cc ..seems to tick over ok but wont go above 10/15 miles an hour misfiring really badly any help would b gr8 the local ford garage dont have any diagnostic equipment old enough to help out
Guest El87cabi
just what i was thinking ginger, if it is theres lots that could cause it to play up as i know all too well, mine still playing up, which sensor did you change btw Was it the ECT sensor?
Guest El87cabi
So the ACT sensor, - White plug on the righthand side of the inlet manifold
Haven't tried that 1 yet but was planning on swapping it today so will see what it does to mine, suspect it has more to do with higher rev's when starting from cold.
I take it you've double checked everything's back as it should be, air hoses aren't blocked etc and have you tried unplugging your ISCV?
There's 2 of the 3 ford fitted :dry: 1 by the fusebox and the other on the left of the throttle bodies.
Guest El87cabi
You might also want to try checking your ECU's not damp and the pins aren't dirty, before you do that though i'd check your Engine speed sensor as i think it's the 1 that tell the coil pack when to fire and my mechanic say they break down under load i.e driving. If your local i have a spare i think works, may not solve the fault but it'd be worth swapping them to see if it makes any difference
