Guest derrick Posted April 9, 2011 Share Posted April 9, 2011 ive just found that the inlet air tempature sensor on my 1.6 efi 1991 was not plugged in and when i did the car runs very eratically but when i disconnect it from the side of the injection unit the car runs fine my question is if i run the car without this will i damage the engine or will i simply use more fuel as i think i am, i drove about fifty miles and used nearly ten quid of petrol does this sensor control the flow of air and petrol mix, and where can i get one? few places ive seen on the web are quote'n £100 plus Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted April 10, 2011 Share Posted April 10, 2011 I would think if connected and working properly, you would use less fuel. If its disconnnected, the ecu goes into default/limp home mode. The sensor measure the temp of air, so depending of temp of the air, depends on how much/little fuel is needed Quote Link to comment Share on other sites More sharing options...
Guest derrick Posted April 10, 2011 Share Posted April 10, 2011 I would think if connected and working properly, you would use less fuel. If its disconnnected, the ecu goes into default/limp home mode. The sensor measure the temp of air, so depending of temp of the air, depends on how much/little fuel is needed cheers m8 i know it sounded like a stupid question i just needed a second opinon i had a look in the haynes guide and it doesnt say much i know it runs in union with the map sensor which is working,i would think that if the sensor aint connected the ecu would act as if the engine is cold so i would be using more fuel but the car idles at 1000 revs. when it went for the mot i got told it was running rich so i think ive found the problem just need to get a new one and replace it. Quote Link to comment Share on other sites More sharing options...
